Leidsime idanaabri saitidel kaevates ühe huvitava programmi kuidas võlle dimensioneerida.
Sai väike õpetav video üles laetud,et äkki tahab keegi veel vaadata.
Kui nüüd kasutamise ka ükskord selgeks saaks,võiks see juba olla autoehituses kaks sammu edasi. Kaoks see katse-eksitus meetod ära ja teaks kuidas asju õigesti teha .
Head vaatamist !
Võllide dimensioneerimine
HM Racing Team
Re: Võllide dimensioneerimine
Kas programm sisaldab ka materjalide omadusi (lubatud pinged)?
Ning võllidele lubatud läbipainde, nihkenurga annab ette?
Offroadiga tegelnud alates 2006.
Ära nüüd nii keerulisi asju ka minu käest küsicasca kirjutas:Kas programm sisaldab ka materjalide omadusi (lubatud pinged)?
Niipalju saime targemaks,et sisaldab vähemalt kõiki terasemarke ,mida venelane eales tootnud on.
Programm peaks tegelikult sisaldama kõike vajalikku .
HM Racing Team
Komplekt on suurem:
Software complex for transmission gear of any scheme design
APM Driving Mechanisms
APM Driving Mechanisms includes following components:
1 APM Drive – component for rotational motion drive mechanism of arbitrary scheme design
2 APM Trans – component for mechanical transmission calculation and design
3 APM Shaft – component for shaft calculation and design
4 APM Bear – component for non-ideal rolling contact bearing calculation. This program include new unique results in the theory of non-ideal contact problem
5 APM Joint – component for machine element joints design. Wide range of joint types can be calculated (threaded, welded, cylindrical (interference fit), splined, keyed joints etc.). Calculations can be made for arbitrary configuration of joint elements, base surface, and loading.
6 APM Graph – 2D graphical editor with parametrization tools.
7 APM Mechanical Data – database for standard machine elements and parts storing. It provides all necessary operations of their specifying, editing and deleting as well as mechanical engineering reference data.
8 APM Material Data – material database
http://www.apm.ru/eng/products/apm/apmdrivingmechanisms
Kunagi sai samasuguseid "katseid" tehtud Soild Edge-ga. Ja mitte ainult võllid, vaid ka näiteks kast, kuhu projekteerisid plekist kaane. Visualiseerisid kaane käima hingedel, määrasid jõud ja visuaalselt (värviliselt) näitas, kus olid kriitilised kohad. Koheselt sai lisatud mõni tugevdus tala või mõnikord piisas ka tugevdusvoldi tegemisest ja asi klaar. jne jne. Ilmselt on selliseid programme palju.
