Ketiga!differ kirjutas:Kas Pajero 2,8TD mootor on hammasrihma või ketiga?
Küsimusi Mitsubishi Pajero 2,8TD 96 kohta
Kas kett vajab ka mingit hooldust? Pingutamist või vahetust teatud kilometraai möödudes.Ptyyp kirjutas:Ketiga!differ kirjutas:Kas Pajero 2,8TD mootor on hammasrihma või ketiga?
Millist marki õli käib:
1. Käigukasti
2. Esisilda
3. Vahekasti
4. Keskmisse difrisse
5. Tagasilda/difrisse
Mitsubishi Galant GTZ 3,0
Valvoline ütleb:
Mitsubishi
Pajero / Shogun
Pajero / Shogun 2.8 TD (1994-2001)
Engine 4M40T + oil cooler Capacity 7,8 liter
Capacity 6,5 liter
Use: Normal
Service intervals:
Change 7500 km / 6 months
MaxLife 15W-40
VR1 Racing Oil 20W-50
All-Fleet 15W-40
Transmission, automatic Capacity 8,5 liter
Use: Normal
Service intervals:
Check 15000 km / 12 months
Change 45000 km / 36 months
MaxLife ATF
Differential, rear (4x4) Capacity 3,2 liter
Use: Normal
Service intervals:
Check 30000 km / 24 months
Change 90000 km / 72 months
HP GL-5 80W-90
Differential, front (4x4) Capacity 1,2 liter
Use: Normal
Service intervals:
HP GL-5 80W-90
Transferbox Capacity 2,5 liter
Use: Normal
Service intervals:
SynPower TDL 75W-90
DuraBlend GL-4 75W-80
DuraBlend GL-4 75W-90
Transmission, manual Capacity 3,7 liter
Use: Normal
Service intervals:
SynPower TDL 75W-90
Hydraulic brakes/clutch system
Use: Normal
Service intervals:
Change 30000 km / 24 months
Brake & Clutch Fluid DOT 3/4
Power steering
Use: Normal
Service intervals:
MaxLife ATF
ATF Type D
Grease Points/nipples, wheel bearings
Use: Normal
Service intervals:
Change 60000 km / 48 months
Multi Purpose Grease
Grease Points/nipples, others
Use: Normal
Service intervals:
Cooling system Capacity 8 liter
Use: Normal
Service intervals:
Coolant Maxlife AF
Coolant AF Extreme
Coolant AF Extra
Steering box Capacity 0,21 liter
Use: Normal
Service intervals:
HP GL-4 80W-90
Mitsubishi
Pajero / Shogun
Capacity 6,5 liter
Use: Normal
Service intervals:
MaxLife 15W-40
All-Fleet 15W-40
Use: Normal
Service intervals:
MaxLife ATF
Use: Normal
Service intervals:
HP GL-5 80W-90
Use: Normal
Service intervals:
HP GL-5 80W-90
Use: Normal
Service intervals:
SynPower TDL 75W-90
Use: Normal
Service intervals:
SynPower TDL 75W-90
Use: Normal
Service intervals:
Power steering
Use: Normal
Service intervals:
MaxLife ATF
ATF Type D
Use: Normal
Service intervals:
Use: Normal
Service intervals:
Use: Normal
Service intervals:
Coolant Maxlife AF
Coolant AF Extreme
Coolant AF Extra
Use: Normal
Service intervals:
HP GL-4 80W-90
Ketil hüdropinguti mis pingutab seni kuni kett, toimib,kui juba liiga külunud on siisdiffer kirjutas:Kas kett vajab ka mingit hooldust? Pingutamist või vahetust teatud kilometraai möödudes.Ptyyp kirjutas:Ketiga!differ kirjutas:Kas Pajero 2,8TD mootor on hammasrihma või ketiga?
http://forum.4x4.ee/viewtopic.php?t=22714
PatrolY61 3.0D 35"
viis 3363923
viis 3363923
Mina ei saanudgi ühte tagumist polti kätte, vasak poolne tuli sõrmega välja aga paremat sai kuumutada ja ehmatada ja ei tulnudki, lõikasin raamil tüki küljest ja vedeleb koos sellega siiani garaazis riiuli all, aga ära sina nii tee, mul oli raamivahetus käsil ja siis võis lõikudadiffer kirjutas:Alumist õõtsa raami külge kinnitavaid polte. Tagumise poldi külge kinnitub ka torsiooni üks ots.taavik kirjutas:Milliseid polte sa sealt alumisest õõtsast kätte tahad saada?
Kuidas sa selle puksi mõtled sealt kätte saada autot ju koos raamiga pressialla ei pane.
PatrolY61 3.0D 35"
viis 3363923
viis 3363923
Nii, uurisin nüüd eelsüüteküünlaid. Visuaalsel vaatlusel selgus, et üks küünal on alles hiljaaegu vahetatud. Paistis välja praktiliselt tutikas. Aga kui ma ta välja keerasin ja pinge taha lükkasin, siis ta kerhelt soojaks läks, aga hõõguma ei hakanud. Teised kolm küünalt paistsid välja suht vanad ja roostesed, aga need hakkasid pingestades ilusti hõõguma. Tundub, et äsja vahetatud küünal on mingi odav ja ebakvaliteetne(ülaservas mingi roheline plastik ring), mis on juba läbi põlenud.TiitR kirjutas:Pakuks esimese hooga mõne kustunud eelsüüteküünla viga?differ kirjutas: Mida arvate probleemiks, kui külma mootoriga käivitada, siis 10-20 sekundit mootor natuke lonkab/puterdab ja ajab sinist suitsu?
Uurisin veel armatuuris vilkuvate esisilla tulede probleemi. Kontrollisin seda sõlme(ei tea kuidas seda nimetatakse), mis lülitab vaakumiga esisilla sisse/välja:
Neliveo kangi liigutades liikus see (inglise keeles Shift rod) ilusti edasi-tagasi.
Kui pikalt ta üldse liikuma peaks? Minul liikus see 1,5-2cm. Aga esisilla tuled jäid ikkagi vilkuma. Kas võiks probleem olla pildil olevas lülitis(Free Wheel Engage Switch ), või selle ühendustes?
Kes oskab öelda, mis asi hakkab undama kusagil mootori ja esiistmete vahelisel alal auto põhja all. Undamine hakkab kusagil 80 km/h 5nda käiguga ja väheneb kuni kadumiseni 90-100 km/h. Käigukastis, esisillas ja tagasillas õlid vahetatud. Vahekastis veel vahetamata, kuna poest sai vastav õli otsa. Aga vaevalt, et see vahekasti õliga seotud on? Undamine jääb järgi, kui gaasipedaali veidi vabastada ja tuleb tagasi kui gaasi anda.
[quote="differ. Visuaalsel vaatlusel selgus, et üks küünal on alles hiljaaegu vahetatud. Paistis välja praktiliselt tutikas. Aga kui ma ta välja keerasin ja pinge taha lükkasin, siis ta kerhelt soojaks läks, aga hõõguma ei hakanud. Teised kolm küünalt paistsid välja suht vanad ja roostesed, aga need hakkasid pingestades ilusti hõõguma. Tundub, et äsja vahetatud küünal on mingi odav ja ebakvaliteetne(ülaservas mingi roheline plastik ring), mis on juba läbi põlenud.[/quote]
Raudselt on se HkT küünal, mul läks neid kohe mitu, kestsid siis päev või 2.
PatrolY61 3.0D 35"
viis 3363923
viis 3363923
