GAZ 3106 -Ataman II
GAZ 3106 -Ataman II
Jeerum-jeerum! :shock:
või
Kas peagi ka meie turul?
GAZ-3106 will be (in 2004...2006) a 7-seat 5-door sport utility on GAZ-2308 platform. Full time 4x4 (with locking transaxle differential). Design by GAZ and Venture Industries (USA). Special framework and chassis based on GAZ-3102 car. Suspension: dipendent (solid axles with coil springs front and leaf springs rear and with stabilizers). Payload: 1,323 lbs. Engines: gasoline (injection), ohc, 4 cylinders in line,
model ZMZ-4061.10 [4063.10]: displacement 2,286 cc (bore 3.62", stroke 3.39"), compression ratio 6.7:1 [8.2:1]. It produce 100 [110] hp @ 4,500 rpm. Torque 133 ft.-lb. @ 2,400 rpm
model ZMZ-405: displacement 2,500 cc
model ZMZ-409: displacement 2,700 cc, carburetor, ohv, 4 cylinders in line, power: 148 hp
model ZMZ-310: V6-3,000 cc
V8-3,500 to 5,500 cc
or diesel GAZ-561: 5-cylinders in line, 2,667 cc displacement, power 136 hp. With this engine the truck will have top speed 93 mph.
jr
Motorsi Jaak
Postitus Postitas jr »
Olen kuulnud, et sillad pidavat mingid cherokee koopiad olema...
Pildilt on näha kah, et päris UAZ'i sillad nad siiski pole. Differ asub juhipool.
Mine “UAZ / GAZ / ZIL jt”
