M: CAT® S60 DUAL SIM
vai
Postitus Postitas vai »
UUS toode!
Caterpillar CAT S60 Outdoor Smartphone (Black)
[attachment=0]2.jpg[/attachment]
Processor: Qualcomm MSM8952-3 (Quad Core 1.5GHz and quad core 1.2GHz)
Operating System: Android 6.0 (Marshmallow)
Display: Super bright 4.7", a-Si AHVA, HD, 1280x720. Protective Corning Gorilla Glass 4
Storage: 32 GB
Memory: 3 GB
Memory card: microSD up to 128GB
Communications: 2G GSM/GPRS/EDGE (850/900/1800/1900 MHz). 3G WCDMA/UMTS/HSPA/HSPA+ (850/900/2100). 4G Cat 4 Bands 1, 3, 7, 8, 20. WiFi 802.11 b/g/n. Bluetooth 4.1. NFC.
Connections: 3.5mm audio jack. micro-USB 2.0, USB-OTG
Camera: Rear 13MP Autofocus + FLIR Thermal Camera. Video 1080p, 30fps. Front 5MP
Sensors: Accelerometer, proximity, ambient light sensor, compass
GPS: GLONASS, GPS, aGPS, Beidou
Battery type: Non-removable Lithium Ion with Quick Charge 2.0 (3800mAh)
SIM type: Nano SIM (Dual Sim)
Dimensions: 147.9 x 73.4 x 12.66 mm
Other: IP68 Certified (waterproof - up to 5m for 60 mins, dust proof, drop test - up to 1.8M, military - MIL-SPEC 810G, Shock and Drop, Operating Temp: -25°C (-13°F) to 55°C (131°F), Category 4 vibration)
PILDID - http://www.catphones.com/en-gb/phones/s60-smartphone
GARANTII - 2aastat
Hind: 669 EUR
kauplus PURETECH
Asukoht - Tallinn, Paasiku 2a, mob. 5132620
puretech@hot.ee
5132620
vai
Re: M: CAT® S60 DUAL SIM
Kel huvi siis 1tk. on saadaval jälle.
5132620
vai
5132620
vai
4x4 sõpradele allahindlus
Viimati muutis vai, L Nov 26, 2016 7:46 am, muudetud 1 kord kokku.
5132620
vai
Nyyd veel parem pakkumine 590 Eur
5132620
vai
Hind langenud - 570 EUR peale
5132620
Bigboss
Postitus Postitas Bigboss »
Palun arvamust selle telefoni kohta, kes on kasutanud ja kes omavad seda, plaanin oma telefoni välja vahetada ja mõtlesin just selle vastu, aga tahaks teada kuidas toimivad seadmed ja muu värk sellel telefonil.
Tänud juba ette.
Bytewize
Postitus Postitas Bytewize »
Mul on. Tibens telefon on.
Aku kestab hädapärast kuni nädala. Kõik töötab kiiresti, vett peab kah reaalselt, käisin ujumas sellega.
Soojuskaamera on legitiimne. Heli valju ja selge.
Ainus miinus on see, et sellele eraldi lisaümbrist ei pakuta kuskil.
Käes tundub normaalne, mitte nagu osad CATi plastikaadid, kuigi võiks ruberoidsem olla, tahab käest libiseda mõnikord.
MeelisV
Postitus Postitas MeelisV »
Bytewize kirjutas:Mul on. Tibens telefon on.
mul on ka (paarimehel samuti) oleme kasutanud 7 kuud.
mul aku kestab ehk kaks päeva mitte rohkem (tegelikuses laen iga öö) - see oleneb ikka sellest mida teed ja kasutad nt. mul on 24/7 andmeside sees jms.
ega ta just kõige kiirem telefon ei ole aga noh selleks peab ikka enne omama mingeid tippmudeleid, et seda mõista
peab vett ja kannatab kukkumist - tõestatud korduvalt
soojuskaamera on OK s.t. sealt ei tasu otsida igal korral null koma täpsusega mõõtetulemust jms. aga näiteks võrdlemiseks ja enamvähem tulemuse saavutamiseks on hea sest see on väga keeruline teema.
ei ole ka profi kaameratega nii et paned fookuse peale ja saad õige tulemuse kõik oleneb materjalist mida mõõdad ja keskkonnast ning .... aga jah kui õpid kasutama on väga hea asi - ise kasutame seda oma töös päris
palju kõige raskem on hinnata pinna peegeldumist ja see on nende kaamerate kõige suurem "vaenlane"
eraldi ümbris ? miks ? telefon on niigi suur ja vee ning põrutuskindel jah ise otsin kah nt. kilet ekraanile aga see on vaid tellimuskaup.
lisaks ütlen, et fotokas pole just kõikse teravam ja kvaliteetsem eriti hämaras, lisaks on kaamera aeglane aga ....
töömehe telefoniks on ikka väga hea ja kui vähegi vaja temperatuuri vaadelda/võrrelda ja kasutada keskkonnas kus on oht kukkuda ja märjaks saada siis super
no fear
Postitus Postitas no fear »
Mis antud telefoni hind hetkel on?
vai
no fear kirjutas:Mis antud telefoni hind hetkel on?
570 EUR
5132620
vai
Üks isend veel saadaval hinnaga 559 EUR
5132620
vai
Novembrikuu pakkumine!
Cat+ rugged akupank.jpg (64.48 KiB) Vaadatud 4069 korda
5132620
Mine “Bizniz”
