Tere,
endine kv sõiduk, peale ostmist läbis koheselt ÜV ja asjad toimivad. Kuid probleemiks puuduv vidin väljalaske küljes kus üks ots ühendatud küttepumbaga ja teine mingi silindritaolise asjandusega. Tundub et mingi klapijuhtimine väljalaskes?
Oskab keegi seletada mida see vidin teeb ja kui teda ei ole mis siis? Allpool link brozüürist mida ta peaks tegema kuid võõramaa arusaamatus keeles.
Kas kellegil selle sõiduki kraana tugijalgasid ka oleks?
http://www.autominded.net/brochure/volv ... 6%2012.jpg
volvo n86 4x4 mingi väljalaske vidin
Re: volvo n86 4x4 mingi väljalaske vidin
Heavy loads and high sneiheden require reliable brakes. Volvo N 86 has four independently working braking systems. An effective brake with two separate circuits and connection for the braking system of the trailer or semi-trailer, a trampling of charge adjustable brake, a separate trade for the operation of the brakes of the trailer or semi-trailer and an exhaust.
Hat voetromsysteem only works with air pressure and there are two gescheidon circuits for the dc and one for the rear wheels. If in the eon of prin Circuits detect occurrence dsn has this goon affect hot braking hat Andoro what eec is very important safety factor! Fashion by hot big remopperviak, 4700 cm, the braking distance is short on go do romvoeringen long moo.
The parking brake acts directly on rear wheels and do do is working voiledig adjustable. This simplifies starting off hot ala do wsgen on eon hailing stsat. Do handbrake bed end with eon in inatrumentenbord mounted trading. Do handbrake is powered by storke schroetveren mon do as air pressure, which hold Thu forward escape charge. Do handbrake is released as mon wear supplies air under pressure, do springs pressed.
Do uitlaatrom provides a krschtigor romworking of the engine. When do uitlsatrem run, connect a kiop do uitlastpijp ate terwiji togelijkortijd stop the fuel injection. By use of the exhaust brake to Makon people save the run, vooringon. Do exhaust is with eon bodiend footswitch.
The remsystoem of Sanhangwagen ot oploggor's hat sang locks on the brake circuit vsn voorwiolon. With the steering column gemonteerdo trade can aanhsngwagon or oplogger wordon inhibited zondor that the vehicle is braked. This is especially important when situatios, wssrbij chance "SCHARON" groped.
Do luchtdrukcomprossor by gears asngedreven, what do bedrijtszekerheid fect root.
See on mägipiduri juhtimine.
Kuna meil mägesid pole, eesti oludes järelikult suht mõttetu.
Tänud,
ei hakka siis seda taastama.
Hundu77
Hundu77
Väga asjatundlik jutt. Üle pikka aja kohe hea naliheeringas kirjutas:See on mägipiduri juhtimine.
Aga tegu on siiski mootoripiduriga, mis pärsib mäest laskudes mootori tööd, kuna seda kasutades ei lasta silindrist gaase välja.
Abimeheks ka sirgelteel hoo aeglustamiseks, kuigi ei oska kommenteeriga kui käredalt ta seda teeb antud isenditel. Uus klapp aga maksis mingiaeg tagasi, vist oli sinna 500 euri kanti
Mägipiduriks loetakse, vähemalt tänapeva autodel muud asja, aga see selleks...
