Phantom Badger
Rohkem või vähem eksootilised mudelid ja margid.
petros
Phantom Badger
Postitus Postitas petros »
Willyse järeltulija
http://www.bbc.com/autos/story/20140422 ... s-for-duty
http://www.boeing.com/boeing/Features/2 ... 19_13.page
The Phantom Badger has some impressive off-roading specs, including a 240 bhp (179 kW) multi-fuel engine, four-wheel drive, all-wheel steering, and a top speed of 80 mph (130 km/h). There are also hydraulic and suspension systems that allow it to travel at speed in rough conditions without exhausting its passengers with excess buffeting. In addition, Boeing says that its 35-in (90-cm) tires can handle logs as thick as telephone poles, and it can carry 3,300 pounds (1,500 kg) of payload, which is an increase over comparable vehicles. The coachwork comes in anything you like, so long as it’s camouflage.
The Phantom Badger is compact – just 60 inches wide – and, with four-wheel steering, it is highly manoeuverable. The setup gives the vehicle a turning circle of just 24ft – fully 10ft tighter than a Mini Cooper’s. Such agility is particularly valuable in urban environments, where the ability to make tight turns and slip through narrow alleys can change the outcome of a battle.
rommel
Re: Phantom Badger
Postitus Postitas rommel »
Välja näeb nagu ATV ja Hummeri ristsugutis (või taksi ja rotveileri, kuidas soovite).
Re: Phantom Badger
Kas mõni inseneri haridusega inimene suudam mulle lahti seletda, kuidas suutsid jänkid ühtes lusessemajtuda mõisted "lihtente konstruktsioon ja hooldus" ning "õhkvedrustus ja nelikroolimine"?
Mine “Muud maasturid”
