lektüüri kodus remontijaile
tt
Postitus Postitas tt »
vaat mis google ette söötis, ehk kulub kellelgi ära...
http://www.pajero.dn.ru/pdf/
http://www.pajero.dn.ru/pdf/pajero-manual-pdf-big/
Factory '89 Manual (PDF)
* Introduction & Master Troubleshooting
* Lubrication & Maintenance
* Front Suspension
* Rear Axle
* Brakes-Service Parking
* Clutch
* Cooling
* Engine -2.6
* Engine -3.0
* Intake & Exhaust
* Fuel System
* Propeller Shaft & Universal Joints
* Rear Suspension
* Power Steering
* Transmission- Manual
* Transmission- Automatic
* Wheels & Tires
* Body
* Heater & AC
* Emission Control Systems
* MPI System
* Introduction & Specs
* Electrical Locations, Inspections etc...
* Wiring Harnesses Diagrams
* Charging System
* Starting System & Ignition System
* Meters & Gauges
* Lighting System
* Wiper & Washer System
* Audio System
* Back Door, Rear Defogger
* Auto-Hub System
Factory Manual (PDF) Montero/Rider '87 Factory Manual (PDF) Mistubishi Starion/Conquest '88
* Intro- Lube & Maintenance
* Front Suspension
* Rear Axle
* Brakes
* Clutch
* Cooling
* 2.6 Engine
* Intake & Exhaust
* Body & Frame
* Fuel System
* Drive Shafts & UV Joints
* Rear Suspension
* Power Steering
* Transmission - Manual
* Transmission - Automatic
* Wheels & Tires
* Body
* Electrical
# Intro & Master Troubleshooting
# Lubrication & Maintenance
# Front Suspension
# Rear Axle
# Brakes- Service & Parking
# Clutch
# Cooling
# Engine
# Intake & Exhaust System
# Fuel System
# Drive Shaft & U-Joints
# Rear Suspension
# Power Steering
# Tranny- Auto & Man.
# Wheels & Tires
# Body
# Heater & AC
# Emission Control System
# Electrical
Stern
Postitus Postitas Stern »
sellel saidil vanad paroolid enam ei toimi :?
on ehk kellegil linki kust 89a. pajerole manuaali saaks?
Maasturid
Legod Varuosadest
Re: lektüüri kodus remontijaile
Postitus Postitas Maasturid »
tt kirjutas:vaat mis google ette söötis, ehk kulub kellelgi ära...
Aga paroolid,et sisse logida?
Siit lehelt leiab ka palju kasulikku http://www.detali.ru/cat/mi/mi.dll
https://www.maasturid.ee
* Wildtrak 2.0 Bi-turbo
urmas
Postitus Postitas urmas »
eks tuleb kasutajaks teha, läbi foorumi arvan
http://www.pajero4x4.ru/
Snegurochka ex.
Stern
Peale tundidepikkust otsimist - http://www.mitsubishilinks.com/
Kui kellegil vaja siis olemas ka pajero sport 98 aasta manuaal, üsna põhjalik tundub
Mine “Mitsubishi”
