Cherokee 95" võtmeta sisenemine
siimu21
Postitus Postitas siimu21 »
Olen uurinud netist võtmeta sisenemise varianti. Tahan teada, kas olen õigesti aru saanud.
Laes on siis selline silm
Ja kui ma telliks e-bayst sellise puldi
Ja programmeeriks nii:
(1) Open the driver’s door and leave it open during the programming process.
(2) Move the mechanical door lock lever on the driver’s door to the LOCK position.
(3) Insert the ignition key and turn it to the RUN position. (Do not start the vehicle.)
(4) After turning the ignition key to the Run position aim the transmitter at the receiver and press the LOCK (right) button for 5 seconds. Once the receiver accepts the programming the door will unlock.
Move to Step 5 If you have more than one transmitter you are going to use with this vehicle. Move to Step 6 If only one Jeep remote is used.
(5) If additional transmitters are to be used on the vehicle each must be programmed during the programming sequence. (Up to 4 transmitters can be programmed to a vehicle) To program additional transmitters: Return the mechanical door lock lever on the driver’s door to the LOCK position and aim the next transmitter at the receiver and press the LOCK (right) button for 5 seconds. Again when the receiver accepts the programming the door will unlock. Repeat step 5 until all transmitters have been programmed.
(6) When all transmitters have been programmed to the receiver, the ignition must be turned off and back on within 20 seconds after programming the last transmitter. When this is done, only the transmitters that were programmed to the vehicle during this procedure will operate the locks.
Kas siis hakkaks asi tööle? Pulti vajutades tulevad kõik uksed lukust lahti?
On kellegil selline töötav süsteem või keegi sellega tegelenud?
Tegija
Re: Cherokee 95" võtmeta sisenemine
Postitus Postitas Tegija »
See asi töötab siis kui autole paigaldatud tehase poolt infrapuna kesklukustus. Kui seda pole siis pöördu signa paigaldajate poole, kes paigaldavad signa ja saad puldi mis avab uksi juhul kui autol kesklukustus olemas. kui ustes mootorid puudu siis saab need paigaldada. on ka olemas ainult lisaseadmed mis puldist avavad sulgevad uksi. Nende paigaldus lihtsam ,aga hind lihtsama signaga sama.
Kontaktid allpool.
kalleo
Postitus Postitas kalleo »
Tegija kirjutas:See asi töötab siis kui autole paigaldatud tehase poolt infrapuna kesklukustus...
Teemaalgataja pildil ju "silm" laes olemas. Ei mäleta enam, aga "silma" all oli miski trükkplaat, minu teada auto poole pealt muud vaja polegi.
vanapagan
Postitus Postitas vanapagan »
1995 Cherokeel on vist originaalis veel see vanem ühe nupuga pult.
Mul 1991 ja see uuem kahe nupuga pult ei sobinud. Vana ühe nupuga töötab aga seda vist ei saa teisele autole progeda.
siimu21
Just, silm on laes olemas ja seal all on trükiplaat. Mõtlesin, et äkki kellegil toimib, või on keegi puldi hiljem ostnud vms. Ja kui programeerimine nii käib, nagu esimese postis siis tundub asi lihtne. Lootsin, et keegi kinnitaks mu juttu.
Ax
Postitus Postitas Ax »
Kui on "silm" laes siis see tähendab infrapuna vastuvõtjat, seega peab pult olema ka infrapuna saatjaga (a'la nagu telekapult).
Kui sellist silma pole siis kasutatakse raadiolaineid.
Neid kahte süsteemi ei saa kuidagi omavahel kokku sobitada (raadiosaatjaga pulti ning infrapuna vastuvõtjat).
siimu21
Ax kirjutas:Kui on "silm" laes siis see tähendab infrapuna vastuvõtjat, seega peab pult olema ka infrapuna saatjaga (a'la nagu telekapult).
Ja milline see infrapuna saatjaga pult on?
Tegija
siimu21 kirjutas:
Infrpunasaatjaga puldil on saatja ,mis nähtav. Meenutab valgusdioodi .
siimu21
Tegija kirjutas:
siimu21 kirjutas:
Kas keegi näitaks mulle pilti, milline see originaalis oli?
kalleo
siimu21 kirjutas:Kas keegi näitaks mulle pilti, milline see originaalis oli?
Ntx 1993 massinal selline. 2 nuppu ja punane led, IR-led üleval otsas. Samas pead ei anna, et "originaal", aga toimis.
siimu21
kalleo kirjutas:
Tänud.
Aga oskab keegi öelda, et kui ma e-bayst tellin sellise siis saan ikka oma autol ka selle tööle?
Kreizi
Postitus Postitas Kreizi »
Kas oled oma auto küljes selle ära lahendanud või asendanud mõne muu analoogse süsteemiga?
Hakkan omal ka uurima, mis teha annab. Võibolla on pult otsad andnud, siis teaks, kust tellida saab, kui juba tellisid.
'94 XJ Chero 4.0, 31"MT, vints, CB
siimu21
Kreizi kirjutas:Kas oled oma auto küljes selle ära lahendanud või asendanud mõne muu analoogse süsteemiga?
Ei ole midagi teinud, pole aega olnud.
