Nissan GQ oluliste osade koodid
Kuna Nissani esindusest raske infot kätte saada. Ja pakutakse ainult rem komplekti täies mahus. Siis toon esile vahekasti laagrite ja tihendite numbrid.
Nissan transfercase rebuild part No's.
Anyone planning on ever re-buidling a Nissan T/Case for different gears or whatever, cut & paste this so you can buy all the ***** before you start.
I got oil in my eye holding one of the seals up to the light to read the miniscule numbers off of it, so be grateful Don't bother with Nissan, they won't sell the individual bearings to anyone off the street, only a full t-case reco kit ($)
Bearings:
6212NC3 (NTN)
6208C3 (NTN)
TM207 (NSK)
6306 (2x) (NTN)
6208ZC3 (NTN)
6213Z (NSK)
Seals:
15 Z 50 72 12 AE (Input)
15 Z 50 72.5 19.5 AE (Rear output)
15 Z 40 75 17.9 AE (Front output)
EDIT: Had the rear output diameter wrong. changed from 60mm to 50mm Another quick thing..
6213Z - this bearing is the big fawker. Make sure to get the one with the circlip groove in it, cause otherwise you will spend the rest of your time on this planet trying to get the end float right to no avail. I got the wrong one, and haven't eaten in weeks, cause I wouldn't let it beat me
They are listed under the same part# in most catalogues
Bearings:
6212NC3 (NTN)
6208C3 (NTN)
TM207 (NSK)
6306 (2x) (NTN)
6208ZC3 (NTN)
6213Z (NSK)
Seals:
Viimati muutis jr, E Mär 20, 2006 7:17 pm, muudetud 1 kord kokku.
With your 6213Z bearing out the prefix N or NR before the numbers when ordering the bearing and that will give you your snap ring groove and the snap ring with the NR prefix, this bearing also weighs in at 990 grams and is 120mm x 65mm x 23mm wide and remember to put it in the right way the first time, its to big to do a trial run.
- MahviaDeTyrk
Lisan kah mõned
GQ PATROL
(Slotted) GQ/GU radius arm bushes N/54560 VB012 $49.12 each
(solid) GQ/GU radius arm bushes NI/54560-01J00 $49.22 each
Lock & rod Filler (locks your fuel lid) N/78827 06J00
Coil Cab rear window N/79712 10J01
Coil Cab rear window rubber N/79710 10J00
Coil cab back panel assembly before 1991 N/79100 10J30
Coil cab back panel assembly after 1991 N/79100 39J31
LWB Turret (roof) N/73101 C6600
Air con fan belt 4.2 petrol N/02117 91023
Fuel pump 4.2 petrol N/17010 03J28
Fan for 4.2 petrol (Auto) N/21060 03JOO
Viscous coupling for 4.2 petrol (Auto) N/21082 03J01
Steel bullbar (winch) N/F2100 34J54A
Master cylinder 4.2 petrol carbi (auto) N/46010 02J00
Free wheeling hub (manual) will fit GU as well N/40250 01J01
Panhard bushes Top one (small) 55135-01J01
bottom one (big) 55135_01J10
Clutch slave cylinder(4.2) NI-30620-01J01
Water pump (TD4.2 & TD4.2T) 21010-06JX8
LWB left hand rear rubber window surround 833331-06J02
SWB rear rubber window surround right side 83332-01J00
SWB rear rubber window surround left side 83333-01J00
SWB & LWB front door exteral wheather strip right side 80822-51N00
SWB & LWB front door exteral wheather strip left side 80823-51N00
SWB & LWB right front door glass Bailey channel 80330-51N00
SWB & LWB left front door glass Bailey channel 80331_51N00
4.2 TD head gasket 11044-06J02 (grade 3)
Front inner axle oil seal NI-40533-01J00 $34.88 each
Lock washer for front wheel bearings NI-43232-45460 $1.68 each
Front wheel bearing inner NI-43210-C9300 $63.16 each
Front wheel bearing outer NI-40215-C6000 $42.78 each
Front hub inner dust seal NI-40227-C8200 $32.66 each
Lock nut for front wheel bearing NI-43231-45460 $13.47 each
Front disc brake shield dust seal NI-40228-01J10 $49.36 each
4.2 TB carb contact points set 22145-89905 $7.66
4.2 TB carb condenser 22102_03J10 $14.06
SWB body mounts to do the whole truck is 2X N95510-06J00 $37.35 each
2X N95520-06J05 $37.35 each
4X N95520-06J00 $41.75 each
total cost being $316.40
Centre console clip 96928-01J00
Centre console cut holder 68430-32J01 about $35 each
left hand front mud flap 63851-05J90
Right hand front mud flap 63850-05J90
Left hand rear mud flap 78811-33J25
Right hand rear mud flap 78810-05J90
Exhaust manifold gasket TB4.2 14036-03J00
Transfer case rear seal for behind hand brake 33142-01J01
Transfer case front pinion oil seal 33216-01J00
Rear diff pinion seal 38183-C7123
Rear axle oil seal 43252-C6001
GU lock washer conversion for GQs
Nut lock, front wheel NI-40262-02J00 1 per side $8 each
Washer for front wheel bearing NI-40264-02J10 1 per side $6 each
Bolts NI-01414-00051 X 2 per side $1.50 each
GQ REPCO PART NUMBERS BELOW
4.2 petrol carbi fan belt 11A1130
4.2 petrol carbi points GH203
4.2 petrol carbi fuel filter Z322
4.2 petrol carbi oil filter ROF17
4.2 petrol carbi valve cover gasket JN839
4.2 petrol carbi inlet manifold gasket JD638
4.2 petrol carbi condenser GH208
GU PATROL (GENUINE)
Front wheel bearings Inner N/43210 C9300 $63.16
Front wheel bearings outer N/40215 C6000 $42.78
Front hub inner dust seals N/40227 C8200 $32.16
Slotted GU/GQ radius arm bushes N/54560 VB012 $49.22 each
Solid GQ/GU radius arm bushes N-45460-01J00 $49.22 each
2.8 diesel swivel hub housing kit SH14
Coil cab back panel assembly 79100 1Y430
GQ PATROL
GU PATROL (GENUINE)
- MahviaDeTyrk
Siin on hunnik Trolli simmekaid koos oem koodide ja mõõtudega
http://www.wubian.com/upload/20093311102081763.xls
Tere.
Kui veel keegi ei tea, siis selline leht on olemas nagu http://nissan4u.com/
See on põhimõtteliselt Nissan Fast(OEM varuosade kataloog) ainult Vin põhine otsing puub.
Loodan, et oli abiks.
- amevier
Re: Nissan GQ oluliste osade koodid
http://nissan4u.com/ on väga hea leht ja osad asjad saab aetud. Aga ometi on tal üks röögatu puudus, valikus pole td42 kone.
Oskab keegi viidata selle puuduseta infokanalile?
Praegu konkreetselt oleks vaja td42-auto standardvedrude Nissani koode.
Edit: avastasin, et parempoolse rooliga variandil on 4,2 diiselkone olemas valikus.
Helar kirjutas:
Kuna mul kastis ka tühikäigul miski kõrin, siis uurin lahendust.
Leidsin sellise viite :
I also found this website that lists the bearings by trade size and name. That way you can just go down to your local industrial supplier and order them (much cheaper than buying a kit specific to FS5R30A).
http://webbersrbguide.com/index.php?opt ... &Itemid=24
I will post it here for reference in case the site goes down:
32203-C8017 - 6308ZNR-C3 - Ball Bearing 40x90x23 (Snap Ring)
- TM308-A-5NR-C3 NTN40x90x23 (Same as above) Input & centermain shaft bearing
32272-01G00 - KMJ3038, but one box had NTN K32x38x26 needle roller bearingn (HL-KMJ30x38x26.3x2)?
32264-21P00 - Yet to identify ?42x48x37.5 split cage (at this point genuine only)
32264-01G00 - K48x53x37.5ZW NTN / BN504806 NSK 48x53x37
32203-01G00 - 62/32-C3 Ball Bearing 32x65x17 Main shaft rear
32248-01G00 - BN504105 NSK 41x46x22 - Needle Roller
32219-01G10 - NTN 7E-HR0711 or 7E-HR0724 / NSK DB503403A - 34x56x17 drawn cup needle roller
32224-01G00 - countershaft thrust bearing AXK4565 NTN 45x60x3mm
32350-01G60 - 34x39x36 needle roller (Split cage) (still unidentified yet) (at this point genuine only)
32225-01G00 - Roller thrust (Yet to bemeasured)
32219-E9020 - 63/22-C3 Ball Bearing 22x56x16 Counter shaft rear
32272-21P20 - FWF232824 NSK (original 23x28x24.5)
32203-31G00 - FJL-3220 NSK HMK3220 NTN Drawn Cup Needle Roller 32x42x20, Main shaft Rear, typically 4WD box
Kuna ma ei tea täpselt kasti koodi siis kõrvutasin patroliga ( mul 97 aasta)
http://nissan4u.com/parts/patrol_gr/el_ ... tration_2/
Ja laagrite koodid paistavad kõik klappima. Nendele nubritele tuginedes võtan enda kasti remondi ette. Eks näis ..
