I like the little tree in the cab - Im not sure you could use it to winch to in a swamp but its worth a try?
do you need these little pieces of metal? Im running out - I could use these
we finally get the front axle finalised and make sure everything moves without hitting anything else - its ok in the up position
...and the down position - we also try every other position we can, and it looks ok
finally start to rebuild the portals
we use our hyper strong 4340/300M Volvo CVs
some paint starts to go on
winch tray for the front is cut
and welded on..
Mouse is narrower than a defender so we cut an original windscreen down and started on the windscreen surround. We take off all excess metal and drill out the puddle welds
fill all the drill holes with weld
cut out a section from the middle of the surround
do a little welding
and then make sure it fits ok
