Cherokee 142kw??? 1994a
puhitom
Postitus Postitas puhitom »
Sai enda wranglerile ostetud mootori doonoriks komplekne chero 1994a ja selle passis oli märgitud 142kw? Kas see on mingi leedu mööda laskmine (auto on leedu teh. passiga) või on selline mingi eri väljalase?
raimo
Postitus Postitas raimo »
142 kW = 190 hp
4.0 Engine Power Ratings
The factory power ratings are as follows:
'87...... XJ: 173hp at 4500rpm, 220lbft @ 2500rpm, redline 5000rpm
'88-'90 XJ: 177hp at 4500rpm, 224lbft at 2400rpm, redline 5000rpm
'91-'95 XJ: 190hp at 4750rpm, 225lbft at 3950rpm, redline 5250rpm
'96-'99 XJ: 190hp at 4600rpm, 225lbft at 3000rpm, redline 5300rpm
'00-'01 XJ: 193hp at 4600rpm, 231lbft at 3000rpm, redline 5300rpm
'91-'95 YJ: 180hp @ 4750rpm, 220lbft @ 3950rpm, redline 5250rpm
'96-'99 TJ: 181hp @ 4600rpm, 222lbft @ 2800rpm, redline 5300rpm
'00-'06 TJ: 190hp @ 4600rpm, 235lbft @ 3200rpm, redline 5300rpm
'93-'95 ZJ: 190hp @ 4750rpm, 225lbft @ 3950rpm, redline 5250rpm
'96-'98 ZJ: 185hp @ 4600rpm, 220lbft @ 2400rpm, redline 5300rpm
'99-'05WJ:195hp @ 4600rpm, 230lbft @ 3000rpm, redline 5300rpm
2004.WJ.
Kiirus kompenseerib kliirensit.
mtsn
Postitus Postitas mtsn »
mul cherokee 95 kah 142kw, alguses mõtlesin samuti et mingi jama, kuna kuskilt šveitsist pärit (ja kindlustus ju ka raisk kallim! :x ), aga tundub et õige värk!
puhitom
mtsn kirjutas:mul cherokee 95 kah 142kw, alguses mõtlesin samuti et mingi jama, kuna kuskilt šveitsist pärit (ja kindlustus ju ka raisk kallim! :x ), aga tundub et õige värk!
mul on õnneks see 142kw auto peal mille passis 4,2 l ja 86kw. Et mul kindlustuse probleeme sellest ei ole.
