Frontera ja monterey (diisel)mootorid
Otsisin aga ei leidnud siit mingit kokkuvõtlikku teemat opeli maasturite mootorite kohta. Kas ma olen õigesti aru saanud et:
Diislid
2.3 >> 5JMWL4 Opel?>> jõuetu ja mitte eriti töökindel
2.5 >> VM Motori >> jõudu natuke on, aga töökindlust ikka mitte. Tegemist EI OLE sama bmw 2.5 diisliga mis omega peal
2.8 >> Isuzu? >> ???
3.1 >> Isuzu >> ???
3.0 >> Isuzu >> esimese põlve common rail, eestis eriti lappida ei osata ja lappida on kallis, aga kui töötab siis üldse mitte halb
2.2 >> opel? >> ???
Bensiin
2.0 85kw >> opel >> pommikindel mootor, aga mitte väga võimas
2.2 >> opel ecotec >> ???
2.4 >> opel >> ???
3.2 >> isuzu? >> ???, EI OLE sama mis omega peal olev MV6
Kas ehk mõni pädevam tegelane oskaks lüngad täita ja mu arusaamu kinnitada või ümber lükata.
Diislid
3.1 >> Isuzu >> ???
2.2 >> opel? >> ???
Bensiin
2.4 >> opel >> ???
Viimati muutis Mahno, K Okt 26, 2011 1:53 am, muudetud 2 korda kokku.
Re: Frontera ja monterey (diisel)mootorid
Europe
1995–1998 Holden Frontera (UT) Sport hardtop (Australia)
The Wizard was known in the United Kingdom as the "Vauxhall Frontera" and in Europe as the "Opel Frontera". It was originally built at the former Bedford Vehicles factory in Luton, UK; it would become known as the IBC factory (Isuzu Bedford Company). In the 1980s the plant had come under joint control between Isuzu and General Motors, with the Frontera being built alongside a number of other commercial vehicle models. The Australian and New Zealand version of the Wizard model range was known as the Holden Frontera.
The early cars (to 1995) had a choice of engines, with the LWB available with either a 2.4-liter petrol (C24NE) engine (developed in the Opel Manta 400) or the 2.3-liter diesel engine originally fitted in the Bedford CF van & Vauxhall Carlton. The Frontera sport (Isuzu Amigo) was available with the 2.0-liter petrol Vauxhall Cavalier engine (C20NE).
In 1995 the model went through a facelift and the Frontera received rear coil springs and a new line up of engines. The SWB gained a new 2.0-liter petrol (X20 series) engine, updated trim, and also the first diesel engine available for the SWB, the 2.8-liter (4JB1-TC). The LWB also had new engines, with the 2.2-liter petrol (X22XE) and the 2.8 diesel 4JB1-TC being made available.
In the 1996–1997 models interior trim, including the dashboard, was changed, and a new 2.5-liter diesel (VM41) engine was fitted. This engine was also used in the Range Rover Classic and Jeep Cherokee in the UK.
2,3 on Opeli enda mootor mitte VM.
Googeldasin mis ma googeldasin, sain niipalju targemaks et selle 2,3 74kw mootori kood on 5JMWL4. Samas ei leidnud ma ühtegi viidet, kus opel selle enda omaks tunnistaks, samas ei tunnista teda omaks ka isuzu
Aga kuidas selle mootori töökindlusega on?
2.3 olen ise omanud. Töökindlusega on nii ja naa. Tavaliselt on õlisurvega probleem. Aga üldiselt on ikka väga jõuetu.Mahno kirjutas:Googeldasin mis ma googeldasin, sain niipalju targemaks et selle 2,3 74kw mootori kood on 5JMWL4. Samas ei leidnud ma ühtegi viidet, kus opel selle enda omaks tunnistaks, samas ei tunnista teda omaks ka isuzu
Jeep GC 2.7CRD
58454535
58454535
agent007 kirjutas:2.3 olen ise omanud. Töökindlusega on nii ja naa. Tavaliselt on õlisurvega probleem. Aga üldiselt on ikka väga jõuetu.Mahno kirjutas:Googeldasin mis ma googeldasin, sain niipalju targemaks et selle 2,3 74kw mootori kood on 5JMWL4. Samas ei leidnud ma ühtegi viidet, kus opel selle enda omaks tunnistaks, samas ei tunnista teda omaks ka isuzu
mul ka miskine kahtlane tunne selle õlisurvega. räägi mis tegid, et see mure lahendada!
- Fitting 38"
Ma ei saanud talvel sellest 2,3 mootorist salongisooja ka kätte. Termostaat ja andurid said vahetatud, kuid ikka oli külm. Pappi ei julgenud ka radika ette panna, kuna mõnet tuttavad oma 2,3 omegad ära küpsetasid sedasi.
Ex: LR DISCO I
EX: Subaru Outback
Ex:Subaru Outback 2105
Ex:Subaru Forester XT 2016
Subaru Outback 2019
Nissan Patrol Y61 2004-
Chevy K1500
Cadillac Escalade ESV
http://reinufoto.wordpress.com/
EX: Subaru Outback
Subaru Outback 2019
Chevy K1500
Vaheta salongi radikas ära siis saad sooja ka
- Fitting 38"
Meil müüdud see ammu juba. Ei olnud ikka see, mis vaja. Täna Disco1 peale jäänud ja rahul. Nii kaua, kui võimalik, eelistan talasildadega maastureid. Fronteral ei sobinud ka juhtimise asend, väga kehva oli pedaale vajutada. Lolli nurga all istme suhtes. Viimase põlve omal enam seda muret pole.siimjuss kirjutas:Vaheta salongi radikas ära siis saad sooja ka
Ex: LR DISCO I
EX: Subaru Outback
Subaru Outback 2019
Chevy K1500
EX: Subaru Outback
Subaru Outback 2019
Chevy K1500
2.3tdi õlisurve jama võib olla sellest et õlipumba hammasratta nuut maas ja survet ei ole.mul juhtus nii ja sellepärast küpsetasin 2 turbot ka läbi.ei osanud selle peale mõeldagi.vahetasin hammaka ära ja surve tagasi.aga turbo ikka õhtal.
- freelander
- Fitting 44"
Vana teema aga ei haknud uut tegema. Kas see isuzu 3.1 diisel mootor on vastupidav ka?
Patrol y61, om648, 8hp75x 38"
- uppund kana
Kestab küll kui ise lollusi ei tee. Vahetad korralikult õli ja keema ei lase on kõik ok.
