K: rear light failure
torque
Postitus Postitas torque »
Kompuuter siis viskab sellise kirja ette kui pidurit vajutan, samas kõik pirnid terved (isegi lisastop tuli) ja õiged sees. Milles probleem on? Ei leia mitte viga üles.
Grand cherokee 2,5TD
virgo
Re: K: rear light failure
Postitus Postitas virgo »
Kaks põhilist vastust on:
1.You probably need a new lamp outage module.
CIRCUIT OPERATION
The Lamp Outage Module (LOM) determines if a rear lighting lamp is not operating. When the ignition switch is in the START or RUN position, circuit A1 from fuse 8 in the Power Distribution Center (PDC) connects to circuit A21. Circuit A21 feeds circuit F87 through fuse 5 in the junction block. Circuits F87 feeds the LOM.
Circuit G46 from the LOM connects to the Vehicle Information Center (VIC) . When the LOM senses a inoperative lamp, the VIC displays the data to the vehicle operator.
Circuit L90 which feeds the tail lamps and side marker lamps, connects to the LOM. From the LOM, circuit L90 continues to the license plate lamps. Circuits L21 and L22 from the LOM power the tail lamps and side marker lamps.
Circuit L50 from the stop lamp switch connects to the LOM. From the LOM, circuits L73 and L74 power the stop lamps and circuit L87 powers the Center High Mounted Stop Lamps (CHMSL) . Circuit Z1 grounds the LOM.
Ja teine:
are you sure that there are no lights out?pay attention to the third brake light because it has 3 bulbs and if one is outit will give you that message.also make sure that all of the bulbs are the right ones.i've seen a lot of people swear that there are no bulbs out when one of the third brake light bulbs is out.another common thing is if there is trailer wiring that can cause problems especially if it is aftermarket or if it gets corroded.i'm just saying be 100% you have eliminated everything before you replace the lamp outage module.im a tech at a jeep dealer and i have never seen a lamp outage module go bad yet.thats not to say it never happens but i work in a shop with 15 techs and its all jeeps and i have never seen it.
Edu.
Virgo
Mudas alates 2003.
virgo
Inimlikust huvist lähtudes-on mingit progressi toimunud?
Virgo
Mudas alates 2003.
crimson
Postitus Postitas crimson »
Terv!
Googeldades,maadlevad selle probleemiga paljud siin laias ilmas ja mõnigi on alla andnud(-:
Endalgi siin paari nädala eest selle vea displeile kuvas.Õnneks oli minul iva keskmises stoptules,millel 2 pirni ei põlenud.Ühe,lükkasin pessa tagasi mis ka tööle hakkas,teine aga oli läbi! Naljakas on see muidugi,et jätsin keskmise pesa tühjaks ning failuret enam ei kuva(-: tänaseni!
Jeep Grand Cherokee LX 5,9L 177kw
torque
Ei ole väga positiivset progressi toimunud :) Tänud Virgole, eks ise hakkasin ka kahtlustama seda tulede plokki nagu su esimesest vastusest lugesin. Teise punkti järgi vaadand, ehk siis pirnid õiged ja keskmisel tulel kõik kolm pirni põlevad. See siis põhjus olla ei saa. Nüüd siis selle ploki üles otsima ja ehk veab ja on pistik oksüdeerunud või midagi sellist. Kus kandis see tulede kontrollplokk asuda võiks?
virgo
Pagasiruumis vasakul oli miski äravõetav kate mille taga nägin ükspäev miskist control modulet. Ei süvenenud kas tegu oli õige asjaga.
Mudas alates 2003.
torque
Saaga jätkub :) leidsin karbi üles jah (vasakul taga nurgas) pistikud ilusad juhtmed terved, eks tuleb ühendused plokis üle joota, ehk on kuskil külmjoode ja loota et siis on korras. Kui ei siis teeb ehk tuttav elektroonik ta korda :) Eks ma anna varsti jälle teada.
helar
Postitus Postitas helar »
kas kruiis töötab ?
Mul ei töötanud ja viga oli pidurikonnas ,kuigi tuled põlesid. veateate kohta ei oska öelda kuna tabloo ka ei töötanud.
Äkki viga seal.
torque
vahepeal palju aega mööda läinud, aga nüüd tuled töötavad jälle. Kellel sama probleem võib kohe sama teha. Sai siis romulast uus moodul külge ja kõik väga hea. Cruise töötas jah enne ka.
