ajee nalja ka VOL3
väikevend
Postitus Postitas väikevend »
Kui põrandat vaja, siis küsi! Erinevad parketid,
linoleum,pvc,laminaat,puit .... 5kaks888kuus8
jr
Motorsi Jaak
Postitus Postitas jr »
+372 5028488
trc
Truth, only truth
Mehaanikunalja
Postitus Postitas trc »
After every flight, Qantas pilots fill out a form, called a "gripe sheet," which tells mechanics about problems with the aircraft. The mechanics correct the problems; document their repairs on the form, and then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humor. Here are some actual gripe sheets submitted by Qantas' pilots (marked with a P) and the solutions recorded by maintenance engineers (S).
By the way, Qantas is the only major airline that has never, ever, had an accident.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what friction locks are for.
P: IFF inoperative in OFF mode.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny. (I love this one!)
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget.
allkiri, 255 sümbolit
Giosk
tel.56661070
KAMAKAS
Postitus Postitas KAMAKAS »
Veel karmidest meestest ja nende tegemistest
http://media.putfile.com/Offroad-Russia
uputaja
Postitus Postitas uputaja »
KAMAKAS kirjutas:Veel karmidest meestest ja nende tegemistest
Ei tea kas SB vol2 oleks seal veel sõitnud ?
rommi
afroäi
Postitus Postitas rommi »
haha... hea tõlge:
http://translate.google.ee/translate_t? ... i%20trummi
Kopige terve link või siis lihtsalt google translatorisse:
hiir hüppas ja kass kargas, vanakaru lõi trummi
eesti > inglise
:D
tyyp07
Postitus Postitas tyyp07 »
rommi kirjutas:haha... hea tõlge:
eesti > inglise
:D
Päris huvitav tõlge :lol:
http://www.rgb.ee
53449661 Kert
Team Linnamehed
trc
Truth, only truth
eesti > inglise
:D
adekvaatsema annab juhul kui eestikeeli kirjutada, e. "vana karu" ikka lahku.
Giosk
tel.56661070
LoJack
Postitus Postitas LoJack »
Proovige seda :P :P :P vähemalt senikaua kuni keegi seda ära ei paranda...
http://translate.google.com/translate_t ... i%20turist
Või siis sisestage "ma olen vaene eesti turist", tõlge eesti keelest inglise keelde...
rommi
afroäi
trc kirjutas:adekvaatsema annab juhul kui eestikeeli kirjutada, e. "vana karu" ikka lahku.
nojah aga kahjuks siis pole enam nii naljakas :D
mrt
Postitus Postitas mrt »
juba sadetakse läänest spämmi ka selles keeles.
Mida vingem maastur seda kaugemale tuleb järgi minna.
[Pilt Kull või kiri[/size]] [Pilt kaubaotsing[/size]] [Pilt4x4]
tai
unistus TR nullist
Postitus Postitas tai »
Kes tehnika huvilised siis pakkuda SIII
aga masin ise usaldusväärne
http://www.youtube.com/watch?v=e-MR6omTN6Q
Juhin tähelepanu she stopped. :lol:
58021221
marko.laagri
Postitus Postitas marko.laagri »
Leidsin ühe koha kus Hummer on parema läbivusega kui D90...
http://www.youtube.com/watch?v=LqBph0o8 ... re=related
malvekas
Postitus Postitas malvekas »
Ema kiri pojale!
Tere kallis pojuke
kirjutan sulle, et sa teaksid, et minul ja ka teistel läheb võrreldes sinuga väga hästi. Ma kirjutan aeglastelt, sest ma tean,et sa ei oska kiiresti lugeda.
Me ei ela enam meie vanas kohas. Isa luges lehest, et enamus õnnetustest juhtub umbes 20km kaugusel kodust, seega me kolisime
Teisipäeval vaksineeriti meid kõiki maavärina vastu. Ma ei saa veel sulle aadressi saata, sest eelmine pere kes siin elas,
võttis maja numbrid kaasa, et nad ei peaks aadressi vahetama. Maja on
päris tore. Mul on isegi pesumasin, pole eriti kindel, et see töötab aga eelmine nädal panin riided sisse, tõmbasin ketist sellest ajast pole
neid näinud. Sinu onu sai töökoha.Tema alluvuses on 500 inimest. Ta töötab nüüd surnuaias muruniitjana. Sinu õde sünnitas eile
lapse. Me veel ei tea kumb sündis, kas poiss või tüdruk, seega ei saa me sulle öelda said sa nüüd onuks või tädiks. Ilm on kah päris kena,
eelmine nädal sadas ainult 2 korda, esimesel korral 3 päeva ja teisel korral 4 päeva. Müristas nii kõvasti, et kana munes ühte muna
neli korda. Saadan sulle veel selle vesti, mida sa nii väga igatsed. Nööbid tõmbasin eest, et paki kaalu vähendada. Nad on vesti paremas
taskus.
Armastusega ;
Sinu ema.
Ps. Oleksin
sulle ka raha saatnud, kuid olin kirja juba kinni
kleepinud…
Cheokee 2,5td
Andsin näpu, varsti kaelani sees .......
vai
Postitus Postitas vai »
tai kirjutas:Kes tehnika huvilised siis pakkuda SIII
Palju SIII kaal võiks olla? maa,vesi õhk :wink:
