Kui pakutakse sama hinnaga gaasirooliamorte "super gaz" ja "Cellular dynamic", siis kumba eelistada?
Pole kummastki eriti midagi kuulnud.
Autoks LR90 aastast 1988
Rooliamordi valik
Rooliamordi valik
- Maasturid
- Legod Varuosadest
Re: Rooliamordi valik
Ülal toodud amortidest ei tea midagi aga sirvisin KONI kataloogi ja leidsin sealt ka LR (küll Disco I)roolile sobiva gaasiamordi.(mul laos olemas)Landy kirjutas:Kui pakutakse sama hinnaga gaasirooliamorte "super gaz" ja "Cellular dynamic", siis kumba eelistada?
Käik:315-521mm
http://www.maasturid.ee
* Wildtrak 2.0 Bi-turbo
* LC120
* LC120
Disco I ja RRC on sama maordiga, kuid Defekal on kinnitus erinev.Maasturid kirjutas: Ülal toodud amortidest ei tea midagi aga sirvisin KONI kataloogi ja leidsin sealt ka LR (küll Disco I)roolile sobiva gaasiamordi.(mul laos olemas)
Käik:315-521mm
Sai webis leiduva alusel valitud Cellular dynamics.
Kas tasub äkki sama tootenimetusega ka tavamordid uued võtta?
Mis te sellest jutust arvate:
Product Description:
The Britpart Cellular Dynamic Shock Absorber represents a significant advance in Land Rover suspension systems. It features a cellular foam insert instead of a normal nitrogen gas or air, this is to stop the oil from boiling. The foam takes up less room which means more room for oil, 50% more, which offers maximum heat dispersion.
This heat dispersion translates to a very subtle but controlled ride that will not fade no matter how hard you push them. They are ideal for a driver who needs more control to compliment performance improvements or to enhance a standard vehicle. The unique design ensures ride comfort and cornering ability is maximised and of course they are superb off-road.
