M: Runva EWX9500-Q EVO vints
Postitatud: N Jaan 24, 2019 2:13 pm
Pakkuda uued Runva EWX9500-Q vintsid
Tõmbetugevus: 9500 lb (4309 kg)
Mootor: (12V) 6.4 kW/8.6 hp
Ülekanne: terasest 3 planetaariga, 80:1
Tross: 9.2 mm x 26.5 m
Kinnituspoltide valem: 254 mm x 114.3 mm
Mõõtmed: 577 mm x 163 mm x 217 mm
Juhtimispult: 3.7 m juhtmega pult/juhtmevaba pult
Kaal: 31.6 kg
Hind: 450.-
Hetkel saadaval 10 vintsi.
Rated line pull 9500 lbs (4309 kgs)
Motor: series wound 12V:Input: 6.4kW / 8.6hp; Output: 2.8kW / 3.8hp
24V:Input: 8.0kW / 10.7hp; Output: 3.2kW / 4.3hp
Gear reduction ratio 80:1
Cable (Dia.× L) Ø3/8"×82.0 ' (Ø9.2mm×25m)
Drum size (Dia.× L) Ø2.8 "×8.8 " (Ø72mm×223 mm)
Mounting bolt pattern 10 "×4.5 " (254mm×114.3 mm) 4-M10
Overall dimensions
(L×W×H) 22.7"×6.3"×8.5"
577mm ×160mm ×217mm
Net weight
Ibs(kg) 69.7 31.6
Pull, Speed, Amperes, Volts (First layer):
Line Pull Line Speed ft/min (m/min) Current A
Ibs (kgs) 12V DC 24V DC Ibs (kgs) 12V DC
0(0) 64.0(19.5) 65.6(20.0) 75 50
4000(1814) 19.7(6.0) 20.3(6.2) 500 360
6000(2722) 19.0(5.8) 19.7(6.0) 570 400
9500(4309) 17.7(5.4) 18.7(5.7) 600 450
Line Pull And Rope Capacity In Layer
Layer Rated line pull lbs (kgs) Total rope on the drum ft (m)
1 9500(4309) 16.1(4.9)
2 7706(3495) 36.4(11.1)
3 6482(2940) 60.0(18.3)
4 5593(2537) 82.0(25.0)
Kontakt: PM või 5kolm98OO9O
Kaal: 31.6 kg
Hind: 450.-
Overall dimensions
577mm ×160mm ×217mm
Net weight
Ibs(kg) 69.7 31.6
