M: Osram LED'idega Bar 126cm (spot/flood)
Postitatud: K Mär 22, 2017 11:31 am
Postitas Mikes
Pakkuda uus ja kasutamata väga kvaliteetne kumer Osram led'idega bar. Riba sees on nii spot (10 kraadi) kui ka flood (40 kraadi) ledid, automaatne niiskuse väljastusklapp.
Müün kuna oli liiga suur projektika jaoks.
Hind: 230€
Tel: 56 364 601
Seisukord: Uus
Tehnilised andmed:
Power: 480W
Luminous Flux: approx 48000lm
Working Voltage: DC 9~32V(fits 12V,24V vehicles)
Number of Chips: 96pcs*5W intense OSRAM LED
Protection Rate: IP67
Color Temperature: Cold White 6500K
Working Temperature: -40~85 degree Celsius
Beam Angle: Spot(10 degree)& Flood(40 degree) Combo
Size(with bracket): approx 1338*120*88mm/52.7*4.7*3.5inch
Size(without bracket):approx 1258*76*88mm/49.5*3*3.5inch
Black extruded Aluminum profile,PC lens
Mounting Bracket: Alu Firm
About 50,000 hours life time
Certified by CE & ROHs
Re: M: Osram LED'idega Bar 126cm (spot/flood)
Postitatud: K Apr 05, 2017 5:04 pm
Postitas Mikes
Hinda alandatud - uus hind 230€
