Tere!
Kui selle siit välja loed, siis anna mullegi teada.
1: Manufactured by DaimlerChrysler Corporation
D: Dodge
7: Truck Without Side Air Bags "CGS"
H: 6001-7000#(2722-3175 kg) GVWR & Hyd. Brake
U: Ram Pickup 4x4
1: Dodge Ram Pick-up "1500"
6: Conventional Cab
D: 5.7L V8 CYL Gasoline (SMPI) (EZA)
8: Check Digit
3: 03
J: St.Louis Assembly North(Fenton, MO)
Body Code: DR6H61
Engine: EZA 5.7L V8 HEMI Engine
Transmission: DGE All 5-Speed Automatic Transmissions
Build Date: March 27, 2003
Code Description
*M9 Cloth 40/20/40 Prem Bench Seat
0B7A FAM:DH TRACKING: 60831T05AA MY:2007
0BJA Pcn 66110-702 Mga 0Bj
0BNA FAM: CS TRACKING: 60803M11 MY:2007
0CDA FAM: DH TRACKING: 61207T19 MY:2007
166S Zone 66-Orlando
1AAS U.S. Dealer Retail
29G Customer Preferred Package 29G
2TGA Customer Preferred Package 2TG
3VGA Anti-Lock Brake Group Discount
3VTA Customer Preferred Discount
4KZP 4X4 Tracking
594S Vehicle Order Tracking
5A6P Waterbase Paint
5I4S Four Wheel Drive (4WD)/(4X4)
5TV BusinessLink Inventory
5ZES 6 1/2 FT. Cargo Box
5ZJS Regular Cab
5ZLS 1500 GVW
610S Florida State Code
6F2 Paint Order Code
6USS Label - U.S. Specifications
910S Florida State Code
A85P 5.7L ENG (EZA)/5SPD A/T 5-45RFE(DGQ)
APAS Monotone Paint
BAZS 136 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BRT Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CGWS Next Generation Front Air Bags**
CGZS Passenger Air Bag On/Off Switch
CKES Front Seat Area Carpet
CLAS Front Floor Mats
CSPS Passenger Assist Handle
CU3S Behind the Seat Storage / Bin
CUSS Overhead Console w/Trip Computer
CVHP Front Center Seat Cushion Storage
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DHES Man Shift-on-the-Fly Transfer Case
DJMS 205MM HD Front Axle
DMH 3.92 Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
-DV Dark Slate Gray
EAGC All Gas Engine
GACS Tinted Glass Windows
GJDS Rear Fixed Window
GNAS Rear View Day/Night Mirror
GNMS Passenger Side Sun Visor w/Mirror
GTSS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
I26S Route 26 - CSX, Tampa, FL
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JPSP Power 6-Way Driver Seat
JRDP Power Driver Seat
LBCS Glove Box Lamp
LMAS Halogen Headlamps
LNJ Fog Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MFDS Bright Grille
MHAS Black Windshield Moldings
MTDS SLT Badge
MURS Dodge Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCS Front Bumper Sight Shields
NAS 50 State Emissions
NBKP EVAP Control System
NFWS 26 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
NHNP Electronically Controlled Throttle
NZDP Next Generation Engine Controller
PX8A Black Clear Coat
QX8S Black Clear Coat
RAAC All Radio Equipped Vehicles
RBKS AM/FM Compact Disc Radio w/Chgr Ctrl
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCFS 4-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TSRS P245/70R17 BSW All Season Tires
TZHP Michelin Brand Tires
WF1S 17" Steel Spare Wheel
WF2S 17X8.0 Steel Chrome Clad Wheels
WLYC All Steel Wheels
WMJP Center Hub
XBSS Pickup Box
XFUS Trailer Tow w/4-Pin Connector Wiring
XMDA Over Rail Box Bedliner
YAAS Build To U.S. Mkt. Specifications
YG7A 2 Additional Gallons of Gas
Z6AS GVW/Payload Rating
ZCDP Spring - Left Front
ZERP Spring - Left Rear
ZRCP Spring - Right Front
ZTRP Spring - Right Rear
