Ingliskeelne seletav sõnastik
http://www.motorera.com/dictionary/
Autonduse sõnastikud
Moderaatorid: jr, boob, Landy, Moderators
- MahviaDeTyrk
Viimati muutis MahviaDeTyrk, P Dets 06, 2009 2:39 pm, muudetud 2 korda kokku.
- MahviaDeTyrk
The Land Rover Dictionary
http://peter.kutschera.at/LR/LandRoverDict.pl
- MahviaDeTyrk
Enam kasutatavad ingliskeelsed akronüümid
(selles esimeses postis olevas sõnastikus on kah paljud - aga mitte kõik)
ABS = AntiLock Brake System
AC = Automotive Customizers www.4x4parts.com
A/C = Air Conditioning
ASE = Automotive Service Excellence
AT = Automatic Transmission
ATF = Automatic Tranny Fluid
BDC = Bottom Dead Center
BJ = Ball Joint
BL = Body Lift
BTDC = Before Top Dead Center
CFM = Cubic Feet Per Minute
CL = Center Link
CV = Constant Velocity
DS = Drive Shaft
ECU = Engine Control Unit
EFI = Electronic Fuel Injection
EGR = Exhaust Gas Recirculation
FSM = Factory Service Manual
HP = High Pinion or Horse Power
IA = Idler Arm
IAB = Idler Arm Brace
IAC = Idle Air Control Valve
IB4TL = In Before The Lockdown
IFS = Independent Front suspension
IRS = Independent Rear Suspension (or Internal Revenue Service)
JGC = Jeep Grand Cherokee
KPR = Kilometers Per Hours
LCA = Lower Control Arm
LSD = Limited Slip Diff
LP = Low Pinion
MAF = Mass Airflow Sensor
MAP = Manifold Air Pressure
MPFI = Multi Port Fuel Injection
MPG= Miles Per Gallon
MPH = Miles Per Hour
MTF = Manual Tranny Fluid
MT = Manual Transmission
OEM = Original Equipment Manufacturer
O2 = Oxygen
PA = Pitman Arm
PB: P'Blaster
PS = Power Steering (could mean Post Script)
PTO = Power Take Off system
RP = Ring and Pinion
RPM = Revolutions Per Minute
SAE = Society of Automotive Engineers
SAS = Solid Axle Suspension
SYE = Slip Yoke Eliminator
SL = Suspension Lift
SOA = Suspension Over Axle
TBI = Throttle Body Injection
TB = Throttle Body
T-Belt = Timing Belt
TBar = Torsion Bar
TDC = Top Dead Center
TPI = Throttle Port Injection (or tuned port injection)
TRE = Tie Rod End
T-Stat = ThermoStat
TSB = Technical Service Bulletin
TT = Twin Turbo
TCase = Transfer Case
TPI= Threads per inch
TPS= Throttle position sensor
UCA = Upper Control Arms
VVT = Variable Valve Timing
WMS = Wheel Mounting Surface
BJ = Ball Joint
BL = Body Lift
CL = Center Link
DS = Drive Shaft
IA = Idler Arm
LP = Low Pinion
O2 = Oxygen
PA = Pitman Arm
PB: P'Blaster
TB = Throttle Body
TBar = Torsion Bar
TRE = Tie Rod End
T-Stat = ThermoStat
TT = Twin Turbo
