M: CAT® B25, B15 & B100 IS AN ULTRA-RUGGED PHONE
vai
Re: M: CAT® B25, B15 & B100 IS AN ULTRA-RUGGED PHONE
Postitus Postitas vai »
heints kirjutas:Mina tassisin sealt siis esimese endale koju. Viskas lõplikult üle puutetundlik ekraan ja muu jura mida helistamiseks tegelikult vaja pole.
Hetkel tundub selline mõnusalt lihtne ja loogiline. See gps asi on ainult segane, olemas on miski google maps aga asukohta see ei määra.
Kiri kodukal GPS:Yes
Internal GPS / Agps
AGPS - Assisted GPS http://en.wikipedia.org/wiki/Assisted_GPS
Peaks töötama maa peal olevatest GPS postide signaali toega nagu üks härra mulle selgitas.
An assisted GPS system can address these problems by using data available from a network. For billing purposes, network providers often count this as a data access, which can cost money depending on the plan.[3]
Assistance falls into two categories:
Mobile Station Based (MSB): Information used to acquire satellites more quickly
It can supply orbital data or almanac for the GPS satellites to the GPS receiver, enabling the GPS receiver to lock to the satellites more rapidly in some cases.
The network can provide precise time.
Mobile Station Assisted (MSA): Calculation of position by the server using information from the GPS receiver
The device captures a snapshot of the GPS signal, with approximate time, for the server to later process into a position.
The assistance server has a good satellite signal, and plentiful computation power, so it can compare fragmentary signals relayed to it.
Accurate, surveyed coordinates for the cell site towers allow better knowledge of local ionospheric conditions and other conditions affecting the GPS signal than the GPS receiver alone, enabling more precise calculation of position.
Kui kellegil veel mingitmoodi selgitus siis jagage....
5132620
traatjalg
Postitus Postitas traatjalg »
A-GPS toimib üle mobiilse internetiühenduse
Internal GPS sellest ei saa aru aga äkki toetab välist gps vastuvõtjat.???
ehitusmasin
Postitus Postitas ehitusmasin »
Küss B100-ja kasutajatele,kuidas töötab ja on lahendatud e-mailindus :?:
+3725013674 Tanel
http://www.ehitusmasinad.ee
Mod.Traktor
ziilike18
Postitus Postitas ziilike18 »
Sai ka B100 ostetud kuna puutekas purunes taaskord :D Mina olen väga ,väga rahul siuke mõnus tummine tükk 8)
Eks me näe kuidas ta metsas hakkama saab.
Ükskord me võidame niikuinii!
530d 01a
heints
Postitus Postitas heints »
ziilike18 kirjutas:Sai ka B100 ostetud kuna puutekas purunes taaskord :D Mina olen väga ,väga rahul siuke mõnus tummine tükk 8)
Kas sul see gps asukohta määrab?
Ifa l60 9,6d
Heints 55 36 944
traatjalg
Minu B100 asukohta ka näidata ei taha.Korra ütleb,et ajutiselt pole asukoht saadaval jne.Kaart mille google maps alla laeb ka vana nagu mammuti s--t.Vist peaks seda mingit moodi torkima,midagi alla laadima jne.GPS aktiveerimine mingit tulemust ei anna seda ei tohikski seal olla see vist mõeldud välise lisaseadmena.Aga mul see junn helistamiseks ka ainult.
ziilike18
Kah puhtalt helistasime telefon... Töö ka siuke suht,et tavalist ei ole mõtekas kasutada saab otsa...
Gpsi pole katsetanud.
530d 01a
Zombi
Postitus Postitas Zombi »
Tere olen ka nüüd B25 Cati kaks päeva kasutand ja kõik ütlevad et ei kuule korralikult,
kas selle B100 mikrofoon on parema kvaliteediga
heints
Kuulmisega probleeme polnud. Kui kedagi huvitab võin õpetada kuidas see telefon ära lõhkuda.
Ifa l60 9,6d
Heints 55 36 944
LR-HD
Postitus Postitas LR-HD »
Lase tulla??? :D
ziilike18
Jah sooviks ka teada ;) Kuulmine ja kõik muu okei
530d 01a
heints
Vajalik töövahend on 2006 a grand cherokee. Telefon paigaldada tagaluugi lukusti süvendisse ja sulgeda jõulise liigutusega luuk. Märgates ,et luuk ei sulgunud korrata protseduuri jõulisemalt.
Tulemuseks kuju nagu banaanil ja katkine ekraan. Helistamis funktsioon toimib endiselt :D
Ifa l60 9,6d
Heints 55 36 944
ziilike18
Ülikõva asi siis ju :)
Esimese laadimisega 7päeva 8)
Edit 26.04 Kannatab igasugust piina (uputamist,muda,tolmu,ülesõitmist jne)... Okei laadija ühendad järgi ,siis kirjutab ,et laadija ühendatud... Võtad,aga laadija ära :D :D Kõrvaklapid lahti ühendatud :D Veitse puusse pandud....
530d 01a
Andrus Michelis
Kui eestikeelne see B 100 on? Täpitähti tunneb? Pöörnä Tõnu lubab telefoniraamatusse kirjutada? Kas kogu menüü on eestikeelne või on mingid alamenüüd ikka tõlkimatta?
traatjalg
Menüü täitsa eesti keelne ja öäüõ ja ÖÄÜÕ olemas,sümboleid ka terve leht.
Mine “Bizniz”
