12. leht 14-st
Re: INEOS Grenadier
Postitatud: K Veebr 21, 2024 6:59 am
Postitas vai
Re: INEOS Grenadier
Postitatud: K Veebr 21, 2024 5:10 pm
Re: INEOS Grenadier
Postitatud: R Mär 01, 2024 12:26 am
Re: INEOS Grenadier
Postitatud: L Mär 02, 2024 7:53 pm
TFL meeksond räägib oma uuest Grendier-ist
https://www.youtube.com/watch?v=rv-Qukvvv70
Re: INEOS Grenadier
Postitatud: T Mär 05, 2024 12:47 am
Re: INEOS Grenadier
Postitatud: K Mär 13, 2024 2:52 pm
Re: INEOS Grenadier
Postitatud: N Mär 14, 2024 12:50 am
Siin siis ametlik nimekiri (nende sisedokumendist) kompaniidest kelle detaile Grendiseri tootmiseks kasutatatukse:
ADLER PELZER GROUP -Floor Trim
AKG THERMAL SYSTEMS INTERNATIONAL -Engine Cooling
APTIV -Wiring Harness
ARLINGTON ENGINEERING SYSTEMS- Brake Pedal Box
MAGNA STEYR FUEL SYSTEMS -Fuel Filler Pipe
BASF POLYURETHANES -Bump Stop, Spring Bed
BASF COATINGS -Coatings
BERGSTROM -HVAC
BF GOODRICH -Off-Road Tyres
BMW -6 Cylinder Diesel and Gasoline Engines
BOSCH -ADAS, Engine ECU, ESC, Steering and Brake Elements
BRANO -Fuel Filler Flap and Bowl
BREMBO -Brake Discs
BREMBO POLAND -Pads and Calipers
BRIDGESTONE EUROPE -Versatile All-Terrain Tyres
CARCOUSTICS -Acoustic Treatments
CARRARO GROUP -Axles
CASCO AUTOMOTIVE (SUZHOU) -Sensors and Power Outlets
COFLE -Shift Lever and Cables
CONTINENTAL AUTOMOTIVE -Control Modules and Sensors
DOGA -Wash and Wiper System
EATON INDUSTRIES (KOREA) -Differential Locks (Front and Rear)
PUREM BY EBERSPÄCHER -Exhaust System
EDSCHA AUTOMOTIVE KAMENICE -Door Arresters
EGR EUROPE -Accessories
EIBACH UK -Coil Spring and Stabiliser Bar
FACIL -Fasteners and Fixings
FRAP -Links and Rods
GESTAMP -Ladder Frame and Body Structures
GOODRIDGE -Hoses
HABERL ELECTRONIC -Gateway
HENGLONG USA CORPORATION - Steering Pump and Reservoir
HENKEL -Foam Parts
HI-LEX EUROPE -Door Cassette
HUTCHINSON - Engine/Transmission Mount
ICS AUTOMOTIVE - Skid Plates
INTERNATIONAL AUTOMOTIVE COMPONENTS -Cockpit Structures, Door Panels and Overhead System
IRISH PRESSING -Body Structures
JOKON -Lighting
JÖRN -Body and Frame Connection
LANDER AUTOMOTIVE -Hoses
LUMEN EUROPE -Control Units and Power Outlets
MAGNA MIRRORS ESPAÑA -Exterior and Interior Mirror
MARELLI AUTOMOTIVE ELECTRONICS (GUANGZHOU) -Control Units
MAXION INCI JANT SANAYI -Steel and Aluminium Wheel Rims
MERGON -Raised Air Intake
MULTIMATIC EU-MATIC -Door Hinges
NAMYANG NEXMO -Steering System
NEUSOFT TECHNOLOGY SOLUTIONS -Infotainment
NEXANS -Engine Harness
NOLDEN CARS & CONCEPTS -Front Lighting
PILKINGTON AUTOMOTIVE -Glazing
PLASFIL - PLÁSTICOS DA FIGUEIRA -Grab Handles and Sun Visor
PLASTIC OMNIUM AUTO INERGY FRANCE -Fuel Tank
RECARO AUTOMOTIVE -Seating
RED WINCHES -Winch
REHAU -Plastic Bumper
SCHWEIKERT/MB SPRITZGUSS -Steel Bumper
SEG AUTOMOTIVE -12V Starter and Generator
SHANGHAI JTR AUTOMOTIVE ELECTRONICS -Steering Column Module
SPICER AYRA CARDAN/DANA -Prop Shafts
STABILUS -Oil Damper
STANDARD PROFIL SPAIN -Sealing Systems
THYSSENKRUPP BILSTEIN -Steering Damper
TREMEC -Transfer Case
U-SHIN -Door Locks and Handles
VITESCO -Fuel Delivery Module
VOESTALPINE AUTOMOTIVE COMPONENTS -Body Structures
WEDO PLASTICS -Mouldings
WÖLFLE -Centre Stack
YANFENG AUTOMOTIVE SAFETY SYSTEMS CO. -Passive Safety and Switches
ZF FRIEDRICHSHAFEN -Transmission and Suspension Systems
Re: INEOS Grenadier
Postitatud: K Mai 22, 2024 4:40 pm
Postitas vai
Re: INEOS Grenadier
Postitatud: R Mai 24, 2024 9:59 am
Ineos to Offer Two More SUVs and Could Build a New U.S. Factory
The upstart British automaker has revealed it will add two new 4x4s in a few years to join the current Grenadier and Fusilier models.
https://www.motortrend.com/news/ineos-t ... Dv0ge6oCV2
Re: INEOS Grenadier
Postitatud: T Juun 11, 2024 5:39 am
Postitas vai
Re: INEOS Grenadier
Postitatud: T Juun 11, 2024 9:35 pm
Postitas ahto42
Re: INEOS Grenadier
Postitatud: N Juun 27, 2024 7:31 pm
Re: INEOS Grenadier
Postitatud: R Juul 12, 2024 12:17 am
Kui tavaline Greandier tundub liiga odav, siis:
https://www.youtube.com/watch?v=f6TrzhWrkZY
Re: INEOS Grenadier
Postitatud: T Juul 16, 2024 11:27 am
Postitas vai
Portal-axled Quartermaster and Station Wagon by LeTech
Ineos Grenadier prototypes
German tuner LeTech is known for its work modifying Mercedes G-Wagens for off-road use, but it’s also now an official Ineos sales and service partner. Welcome then to its hardcore, portal-axled Grenadier.
Both a Quartermaster and Station Wagon will be at Goodwood, with the new axles and wheel hubs increasing ground clearance by 250mm to 514mm and wading depth from 800mm to 1050mm. There are chunky off-road tyres too and a lightbar up top on the roof. We want to have a go immediately.
- grenad.jpg (146.19 KiB) Vaadatud 6339 korda
Re: INEOS Grenadier
Postitatud: T Aug 06, 2024 7:20 am
Tibus tegei muideks oma Grenadieri portaalide kompleti juba eelmsiel aastal avalikuks, ag LeTech on ametlikprtener.
