Sildades õli vahetamine.
quentin
Postitus Postitas quentin »
NImelt oman Pajero 1988 2,5 diisel ja 62 kW. Mis õli läeheb sellele masinale sildadesse?
Tänud!
Allar
Postitus Postitas Allar »
Pane 80-w90 ja peaks vaga hea saama.
PatrolY61 3.0D 35"
viis 3363923
taavik
Postitus Postitas taavik »
Category : Cars
Make : Mitsubishi
model : Pajero / Shogun (1983 - )
type : Pajero / Shogun 2.5 TD (1989 - 1991)
Engine 4D56
ˇ Capacity : Capacity 6,3 liter
: Filter 0,8 liter
ˇ Use condition : Normal
ˇ Service intervals : Change 7500 km / 6 months
ˇ Recommendation : MaxLife Synthetic 5W-40
: MaxLife 15W-40
: SynPower MXL 5W-30
: DuraBlend MXL 5W-40
: DuraBlend 10W-40
: DuraBlend Diesel 5W-40
ˇ Use condition : Severe
ˇ Service intervals : Change 4000 km
: MaxLife 15W-40
: DuraBlend 10W-40
Differential, rear, limited slip (4x4)
ˇ Capacity : Capacity 2,6 liter
ˇ Service intervals : Change 45000 km / 36 months
ˇ Recommendation : HP GL-5 80W-90 LS
Differential, rear (4x4)
ˇ Service intervals : Check 30000 km / 24 months
: Change 90000 km / 72 months
: HP GL-4 80W-90
Differential, front (4x4)
ˇ Capacity : Capacity 1,1 liter
: HP GL-4 80W-90
Transferbox
ˇ Capacity : Capacity 2,3 liter
ˇ Service intervals : Check 15000 km / 12 months
ˇ Recommendation : DuraBlend GL-4 75W-80
: HP GL-4 80W-90
Transmission, automatic 4/1
ˇ Capacity : Capacity 7,2 liter
ˇ Recommendation : MaxLife ATF
: ATF Type D
Transmission, manual 5/1
ˇ Capacity : Capacity 2,5 liter
: HP GL-4 80W-90
Hydraulic brakes/clutch system
: Change 30000 km / 24 months
ˇ Recommendation : Brake & Clutch Fluid DOT 3/4
Power steering
ˇ Capacity : Capacity 1,06 liter
: ATF Type D
Grease points/nipples, others
ˇ Recommendation : Multi Purpose Grease
Grease points/nipples, wheel bearings
ˇ Service intervals : Change 60000 km / 48 months
Cooling system
ˇ Capacity : Capacity 8,8 liter + rear heater
: Capacity 8 liter
ˇ Recommendation : MaxLife Coolant AF
: MaxLife Coolant AF 50/50 RTU
Steering box
ˇ Capacity : Capacity 0,21 liter
ˇ Recommendation : HP GL-4 80W-90
rt23
Postitus Postitas rt23 »
jaan mmc kirjutas:LSD toimib normaalselt vaid väheste õlidega, üheks, mis oma otstarvet täidab on SAF-XJ.
Mis kaubamärgi alt seda otsima peaks, palju liitri hind on umbes?
rt23 kirjutas:
Käigukasti Õli SAF-XJ SAE 75W-140 1L Castrol - 435.00EEK
http://www.autokaubad24.ee/product_info ... 8f6ddcda42
Mine “Mitsubishi”
